Ana içeriğe geç
Greist Buttonholer Fork Arm Spring Replacement
Neye ihtiyacın var
    1. Greist Buttonholer Fork Arm Spring Replacement, Unscrew the Lower Hook Holding the Spring: adım 1, 3 resimden 1. Greist Buttonholer Fork Arm Spring Replacement, Unscrew the Lower Hook Holding the Spring: adım 1, 3 resimden 2. Greist Buttonholer Fork Arm Spring Replacement, Unscrew the Lower Hook Holding the Spring: adım 1, 3 resimden 3.
      • Unscrew the screw located underneath fork arm using a Flathead screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Greist Buttonholer Fork Arm Spring Replacement, Remove the Lower Hook: adım 2, 3 resimden 1. Greist Buttonholer Fork Arm Spring Replacement, Remove the Lower Hook: adım 2, 3 resimden 2. Greist Buttonholer Fork Arm Spring Replacement, Remove the Lower Hook: adım 2, 3 resimden 3.
      • Raise the fork arm so that it is parallel with the upper hook.
      • Turn the lower hook towards you from the bottom, and remove.
      FixBot'a Sor
      Yorum Ekle
    3. Greist Buttonholer Fork Arm Spring Replacement, Replace the Spring: adım 3, 2 resimden 1. Greist Buttonholer Fork Arm Spring Replacement, Replace the Spring: adım 3, 2 resimden 2.
      • Remove the old spring from the hook.
      • Add the new spring to the hook.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Michael Sykes
552 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-6, Brown Fall 2014 USF Tampa, Team 3-6, Brown Fall 2014 üyesi
USFT-BROWN-F14S3G6
5 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
Will the spring look distorted if it needs replacing?
Sarah Turnbull - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 35
Her zaman: 555
