Ana içeriğe geç
Griffin iFM 4027 LCD Screen Cover Replacement
Neye ihtiyacın var
  1. Griffin iFM 4027 LCD Screen Cover Replacement, Left Side Panel: adım 1, 1 resimden 1.
    • Lodge the tip of the plastic opening tool into the top arc where the side and main part of the device meet.
    • Push the plastic opening tool upward until the side panel detaches.
  2. Griffin iFM 4027 LCD Screen Cover Replacement: adım 2, 3 resimden 1. Griffin iFM 4027 LCD Screen Cover Replacement: adım 2, 3 resimden 2. Griffin iFM 4027 LCD Screen Cover Replacement: adım 2, 3 resimden 3.
    • Slide the plastic opening tool along the panel seam and push upward until the side panel detaches from the main device.
    • Turn over the detached side panel, so that the outer side is facing downward.
    • Then use your fingers to disassemble the panel button and set it off to the side.
  3. Griffin iFM 4027 LCD Screen Cover Replacement, Right Side Panel: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    iFixit Opening Tool
    $1.99
    • First, lodge the tip of the plastic iFixit opening tool into the top corner of the device.
    • Apply pressure upward with the iFixit Opening Tool. This should release the two panels away from each other.
  4. Griffin iFM 4027 LCD Screen Cover Replacement: adım 4, 3 resimden 1. Griffin iFM 4027 LCD Screen Cover Replacement: adım 4, 3 resimden 2. Griffin iFM 4027 LCD Screen Cover Replacement: adım 4, 3 resimden 3.
    • Use your fingers to separate the right side panel from the device.
    • Turn the panel over so that the outer edge is facing downward.
    • Use your fingers to dislodge the buttons, and then set them aside for later.
  5. Griffin iFM 4027 LCD Screen Cover Replacement, Central Button: adım 5, 2 resimden 1. Griffin iFM 4027 LCD Screen Cover Replacement, Central Button: adım 5, 2 resimden 2.
    • Use your fingers to push down on the center button and move it to the left, sliding it out from under the front panel.
    • Once removed, set the center button aside.
  6. Griffin iFM 4027 LCD Screen Cover Replacement: adım 6, 3 resimden 1. Griffin iFM 4027 LCD Screen Cover Replacement: adım 6, 3 resimden 2. Griffin iFM 4027 LCD Screen Cover Replacement: adım 6, 3 resimden 3.
    • Notice in the attached image that the backside of the button has an elevated corner. This corner must be applying pressure on the golden plate seen in the picture to the right. The center pressure point of the button must also apply pressure to the golden plate in the middle. These plates are both circled in red in the picture to the left.
    • Carefully slide in the button, flat side first (the side not containing the high corner).
  7. Griffin iFM 4027 LCD Screen Cover Replacement, Media Player Accessory: adım 7, 2 resimden 1. Griffin iFM 4027 LCD Screen Cover Replacement, Media Player Accessory: adım 7, 2 resimden 2.
    • Carefully remove the circuit board and attached LCD component from the device by pulling it towards the open left side.
  8. Griffin iFM 4027 LCD Screen Cover Replacement: adım 8, 1 resimden 1.
    • Carefully lift the rectangular screen cover off the LCD screen.
  9. Griffin iFM 4027 LCD Screen Cover Replacement, LCD Screen Cover: adım 9, 2 resimden 1. Griffin iFM 4027 LCD Screen Cover Replacement, LCD Screen Cover: adım 9, 2 resimden 2.
    • Place the screen cover on top of the LCD so it covers its entirety. Carefully slide the circuit board/LCD back into the device.
Sonuç
After installation, the device should look similar to that which is depicted in the cover image (top right of page).
Alexander
101 İtibar
6 adet Kılavuz yazıldı
Ekip
Clemson, Team 15-3, Benson Spring 2012 Clemson, Team 15-3, Benson Spring 2012 üyesi
CLEM-BENSON-S12S15G3
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 1,072
