Ana içeriğe geç
HASEE Z6-SL7D1 RAM Replacement
Neye ihtiyacın var
  1. HASEE Z6-SL7D1 RAM Replacement, RAM: adım 1, 2 resimden 1. HASEE Z6-SL7D1 RAM Replacement, RAM: adım 1, 2 resimden 2.
    • Flip your laptop over so the bottom is facing up and set it on a flat surface.
    • Use a Phillips #0 screwdriver to remove the two 6 mm screws that secure the battery.
  2. HASEE Z6-SL7D1 RAM Replacement: adım 2, 2 resimden 1. HASEE Z6-SL7D1 RAM Replacement: adım 2, 2 resimden 2.
    • Gently lift the battery from the laptop.
  3. HASEE Z6-SL7D1 RAM Replacement: adım 3, 2 resimden 1. HASEE Z6-SL7D1 RAM Replacement: adım 3, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove fourteen 6 mm screws from the back panel.
  4. HASEE Z6-SL7D1 RAM Replacement: adım 4, 2 resimden 1. HASEE Z6-SL7D1 RAM Replacement: adım 4, 2 resimden 2.
    • If your laptop is equipped with an optical drive, carefully slide it out.
    • Alternatively, if the optical drive bay houses a hard drive tray, remove the tray by unscrewing any securing screws and gently pulling it out.
  5. HASEE Z6-SL7D1 RAM Replacement: adım 5, 2 resimden 1. HASEE Z6-SL7D1 RAM Replacement: adım 5, 2 resimden 2.
    • Carefully slide a plastic spudger or opening tool along the edges of the back panel.
    • Gradually lift the panel away from the laptop chassis, ensuring not to force it and risking damage to internal components.
  6. HASEE Z6-SL7D1 RAM Replacement: adım 6, 3 resimden 1. HASEE Z6-SL7D1 RAM Replacement: adım 6, 3 resimden 2. HASEE Z6-SL7D1 RAM Replacement: adım 6, 3 resimden 3.
    • Use your fingers or a spudger to gently press the clips on the sides of the SO-DIMM slots outward to release the memory modules.
    • The RAM sticks will pop out at about a 45-degree angle.
    • Once the RAM sticks disengage, carefully slide them out of the slot at the same angle.
  7. HASEE Z6-SL7D1 RAM Replacement: adım 7, 2 resimden 1. HASEE Z6-SL7D1 RAM Replacement: adım 7, 2 resimden 2.
    • When installing new memory sticks, align them with the SO-DIMM slots at the same angle and gently press them downward.
    • You will hear a click, indicating that it is securely in place.
  8. HASEE Z6-SL7D1 RAM Replacement: adım 8, 2 resimden 1. HASEE Z6-SL7D1 RAM Replacement: adım 8, 2 resimden 2.
    • Replace the back case.
    • Insert the optical drive back into its designated slot.
    • Replace the battery.
    • Use a Phillips #0 screwdriver to secure the fourteen 6 mm screws on the back case.
    • Use a Phillips #0 screwdriver to replace the two 6 mm screws that secure the battery.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jiayi Liu
175 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 85
