Ana içeriğe geç
HKC P771A Camera Replacement
Neye ihtiyacın var
  1. HKC P771A Camera Replacement, Camera: adım 1, 3 resimden 1. HKC P771A Camera Replacement, Camera: adım 1, 3 resimden 2. HKC P771A Camera Replacement, Camera: adım 1, 3 resimden 3.
    • Remove back of tablet using the plastic opening tool
    • Slide the opening tool between the back of the tablet and the digitizer
    • Lift along the edges until the back of the tablet and the digitizer are separated
  2. HKC P771A Camera Replacement: adım 2, 2 resimden 1. HKC P771A Camera Replacement: adım 2, 2 resimden 2.
    • Remove yellow tape around the edges of the battery
    • The battery is located on the right side of the tablet when the screen is facing downwards and the camera is on top
  3. HKC P771A Camera Replacement: adım 3, 3 resimden 1. HKC P771A Camera Replacement: adım 3, 3 resimden 2. HKC P771A Camera Replacement: adım 3, 3 resimden 3.
    • Pry battery away from the back of the tablet until the battery is completely separated from the adhesive
  4. HKC P771A Camera Replacement: adım 4, 1 resimden 1.
    • Remove yellow tape that is securing the camera wires
  5. HKC P771A Camera Replacement: adım 5, 2 resimden 1. HKC P771A Camera Replacement: adım 5, 2 resimden 2.
    • Remove silver foil from the back of the camera using the blue opening tool
  6. HKC P771A Camera Replacement: adım 6, 1 resimden 1.
    • Lift the bronze, L-shaped ribbon
    • The camera is attached to the end of this ribbon so it will move with it
  7. HKC P771A Camera Replacement: adım 7, 1 resimden 1.
    • Flip up the black bar located on the motherboard
    • The black bar is to the left of the camera, where the ribbon is attached to the motherboard
  8. HKC P771A Camera Replacement: adım 8, 1 resimden 1.
    • Remove the bronze, L-shaped ribbon from inside the black bar
  9. HKC P771A Camera Replacement: adım 9, 1 resimden 1.
    • Your camera is now removed from the tablet
Sonuç
Sara Hill
101 İtibar
2 adet Kılavuz yazıldı
Ekip
Ohio State, Team 2-3, Garvin Fall 2015 Ohio State, Team 2-3, Garvin Fall 2015 üyesi
OSU-GARVIN-F15S2G3
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 169
