Ana içeriğe geç
HKC P771A Digitizer Replacement
Neye ihtiyacın var
  1. HKC P771A Digitizer Replacement, Digitizer: adım 1, 2 resimden 1. HKC P771A Digitizer Replacement, Digitizer: adım 1, 2 resimden 2.
    • Remove back of tablet using the plastic opening tool
    • Slide the opening tool between the back of the tablet and the digitizer
    • Lift along the edges until the back of the tablet and the digitizer are separated
  2. HKC P771A Digitizer Replacement: adım 2, 2 resimden 1. HKC P771A Digitizer Replacement: adım 2, 2 resimden 2.
    • Remove 4 screws located on the red motherboard
    • The red motherboard will be loose, but does not need to come completely unattached
  3. HKC P771A Digitizer Replacement: adım 3, 1 resimden 1.
    • Remove 7 screws located around the edges of the tablet
    • 5 screws are visible around the edges of the device and 2 screws are located underneath the red motherboard
  4. HKC P771A Digitizer Replacement: adım 4, 1 resimden 1.
    • Lift digitizer from the screen
    • After removing all of the screws, the screen should easily separate from the digitizer
  5. HKC P771A Digitizer Replacement: adım 5, 1 resimden 1.
    • Now you can replace the old digitizer with a new one
Sonuç
Sara Hill
101 İtibar
2 adet Kılavuz yazıldı
Ekip
Ohio State, Team 2-3, Garvin Fall 2015 Ohio State, Team 2-3, Garvin Fall 2015 üyesi
OSU-GARVIN-F15S2G3
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 264
