Ana içeriğe geç
HKC P776A Battery Replacement
Neye ihtiyacın var
  1. HKC P776A Battery Replacement, Separating Digitizer and Case: adım 1, 1 resimden 1.
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Battery Replacement: adım 2, 2 resimden 1. HKC P776A Battery Replacement: adım 2, 2 resimden 2.
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Insert the plastic opening tool between the battery and case.
    • Apply leverage to break the glue that is attaching the battery to the case.
  4. HKC P776A Battery Replacement: adım 4, 1 resimden 1.
    • Continue breaking the glue along the perimeter of the battery until the battery can be removed.
    • Breaking all the glue between the battery and case may take a long time.
  5. HKC P776A Battery Replacement: adım 5, 2 resimden 1. HKC P776A Battery Replacement: adım 5, 2 resimden 2.
    • Using the soldering iron, heat up the solder that is attaching the battery to the motheboard.
    • The heat from the soldering iron may cause personal injury or damage the internal components of the tablet.
  6. HKC P776A Battery Replacement: adım 6, 1 resimden 1.
    • Suck up the leftover solder using the desoldering pump.
    • Remove the battery from the motherboard.
Sonuç
Ryan Gornati
409 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-6, Remmell Winter 2015 USF Tampa, Team 7-6, Remmell Winter 2015 üyesi
USFT-REMMELL-W15S7G6
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 639
