Parçalar
Hiçbir parçaya gerek yok.
  1. Insert the plastic opening tool between the digitizer and the case.
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. Slide the spudger along the perimeter of the device to fully separate the two pieces. Slide the spudger along the perimeter of the device to fully separate the two pieces.
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Use your fingers to pop the screen out from the digitizer. Use your fingers to pop the screen out from the digitizer.
    • Use your fingers to pop the screen out from the digitizer.
  5. Use the tip of the spudger to release the latches on the motherboard. Use the tip of the spudger to release the latches on the motherboard.
    • Use the tip of the spudger to release the latches on the motherboard.
  6. Remove the cable from the motherboard.
    • Remove the cable from the motherboard.
Sonuç
Spencer Pheasant
301 İtibar
3 adet Kılavuz yazıldı
Takım
USF Tampa, Team 7-6, Remmell Winter 2015 USF Tampa, Team 7-6, Remmell Winter 2015 üyesi
USFT-REMMELL-W15S7G6
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 3
Her zaman: 99
