Ana içeriğe geç
HKC P776A Motherboard Replacement
Neye ihtiyacın var
  1. HKC P776A Motherboard Replacement, Separating Digitizer and Case: adım 1, 1 resimden 1.
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Motherboard Replacement: adım 2, 2 resimden 1. HKC P776A Motherboard Replacement: adım 2, 2 resimden 2.
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Motherboard Replacement, Separating the Screen and Digitizer: adım 3, 2 resimden 1. HKC P776A Motherboard Replacement, Separating the Screen and Digitizer: adım 3, 2 resimden 2.
    • Use your fingers to pop the screen out from the digitizer.
  4. HKC P776A Motherboard Replacement, Removing the Optical Cord from the Motherbaord: adım 4, 1 resimden 1.
    • With the plastic opening tool, lift the black latch up.
  5. HKC P776A Motherboard Replacement: adım 5, 1 resimden 1.
    • Pull the optical cord out from the motherboard.
  6. HKC P776A Motherboard Replacement, Separating the Screen and the Digitizer: adım 6, 2 resimden 1. HKC P776A Motherboard Replacement, Separating the Screen and the Digitizer: adım 6, 2 resimden 2.
  7. HKC P776A Motherboard Replacement, Removing the Cable from the Motherboard: adım 7, 2 resimden 1. HKC P776A Motherboard Replacement, Removing the Cable from the Motherboard: adım 7, 2 resimden 2.
    • Use the tip of the spudger to release the latches on the motherboard.
  8. HKC P776A Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the cable from the motherboard.
  9. HKC P776A Motherboard Replacement, Removing the Cable from the Moatherboard: adım 9, 2 resimden 1. HKC P776A Motherboard Replacement, Removing the Cable from the Moatherboard: adım 9, 2 resimden 2.
  10. HKC P776A Motherboard Replacement: adım 10, 2 resimden 1. HKC P776A Motherboard Replacement: adım 10, 2 resimden 2.
    • Remove the camera from the device.
  11. HKC P776A Motherboard Replacement, Wifi Antenna: adım 11, 2 resimden 1. HKC P776A Motherboard Replacement, Wifi Antenna: adım 11, 2 resimden 2.
    • Peel off the tape that is attaching the wifi antenna to the case.
  12. HKC P776A Motherboard Replacement: adım 12, 1 resimden 1.
    • Using the soldering iron, heat up the solder that is attaching the antenna to the motheboard.
    • The heat from the soldering iron may cause personal injury or damage the internal components of the tablet.
  13. HKC P776A Motherboard Replacement: adım 13, 1 resimden 1.
    Bu adımda kullanılan alet:
    Desoldering Pump
    $3.99
    Satın Al
    • Suck up the leftover solder using the desoldering pump.
    • Remove the wifi antenna from the motherboard.
  14. HKC P776A Motherboard Replacement, Battery: adım 14, 1 resimden 1.
    • Insert the plastic opening tool between the battery and case.
    • Apply leverage to break the glue that is attaching the battery to the case.
  15. HKC P776A Motherboard Replacement: adım 15, 1 resimden 1.
    • Continue breaking the glue along the perimeter of the battery until the battery can be removed.
    • Breaking all the glue between the battery and case may take a long time.
  16. HKC P776A Motherboard Replacement: adım 16, 2 resimden 1. HKC P776A Motherboard Replacement: adım 16, 2 resimden 2.
    • Using the soldering iron, heat up the solder that is attaching the battery to the motheboard.
  17. HKC P776A Motherboard Replacement: adım 17, 1 resimden 1.
    • Remove the battery from the motherboard.
  18. HKC P776A Motherboard Replacement, Motherboard: adım 18, 3 resimden 1. HKC P776A Motherboard Replacement, Motherboard: adım 18, 3 resimden 2. HKC P776A Motherboard Replacement, Motherboard: adım 18, 3 resimden 3.
    • Using the screwdriver, remove the four 4mm by 1.5mm screws that are attaching the motherboard to the case.
  19. HKC P776A Motherboard Replacement: adım 19, 2 resimden 1. HKC P776A Motherboard Replacement: adım 19, 2 resimden 2.
    • Remove the black material that is covering the speaker.
  20. HKC P776A Motherboard Replacement: adım 20, 1 resimden 1.
    • Insert the spudger into the speaker slot on the back of the case.
  21. HKC P776A Motherboard Replacement: adım 21, 1 resimden 1.
    • Push the speaker out of the case with the spudger.
  22. HKC P776A Motherboard Replacement: adım 22, 1 resimden 1.
    • Remove the motherboard from the case.
Sonuç
Ryan Gornati
409 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-6, Remmell Winter 2015 USF Tampa, Team 7-6, Remmell Winter 2015 üyesi
USFT-REMMELL-W15S7G6
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 168
