Giriş
This guide will walk the user through the basic steps necessary to replace the LCD screen on the HKC p886a 8" tablet.
Neye ihtiyacın var
Insert the flat tip of the metal spudger into the seam between the back panel and the screen.
Slide the spudger across the perimeter of the device and gently pry apart at each corner.
After the pressure clamps are released orient the device so that the speaker is to the right and the screen is tilted away from you.
Gently bend the matrix away from the screen to release the pressure clamps.
Bend one side at a time applying equal force in order to reduce stress on the matrix from the bending.
Once all pressure clamps are disengaged, separate the screen and matrix without touching the front of either component.
Replacement matrices can be found at this link: screensurgeons.com
Bir başkası bu kılavuzu tamamladı.
