Giriş
If your HMD Barbie Phone (model number TA-1420) is not powering on or the screen is not turning on, you may need to replace the motherboard. This part is the central brain of the phone and contains the video ribbon, which could be the cause of the screen not turning on. It also contains the link between the keypad buttons and phone input, so it could be the cause of the buttons not working.
Make sure to check out these troubleshooting guides before removing the backplate to ensure that replacing this part is the proper next step:
HMD Barbie Phone Keyboard Not Typing
HMD Barbie Phone Screen Not Turning On
Before starting this guide, make sure your Barbie Phone is fully powered off. Follow the steps in this guide to replace the motherboard.
Neye ihtiyacın var
Fully power off the phone.
Remove the backplate by gripping it around the edges and pulling away from the phone.
Use the opening tool to remove the clear plastic clip near the hinge of the phone securing the motherboard.
