Ana içeriğe geç
HMDX Chill Battery Replacement
Neye ihtiyacın var
  1. HMDX Chill Battery Replacement, Remove Rubber Base: adım 1, 3 resimden 1. HMDX Chill Battery Replacement, Remove Rubber Base: adım 1, 3 resimden 2. HMDX Chill Battery Replacement, Remove Rubber Base: adım 1, 3 resimden 3.
    • Insert a metal spudger under the rubber base.
    • Pry the rubber base off.
  2. HMDX Chill Battery Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
  3. HMDX Chill Battery Replacement: adım 3, 2 resimden 1. HMDX Chill Battery Replacement: adım 3, 2 resimden 2.
    • Grip the base of the HMDX Chill.
    • Pull the base upwards.
  4. HMDX Chill Battery Replacement, Locate the Battery: adım 4, 2 resimden 1. HMDX Chill Battery Replacement, Locate the Battery: adım 4, 2 resimden 2.
    • Once the base has been removed from the rest of the speaker locate the battery.
    • It may or may not be in a wrapper.
  5. HMDX Chill Battery Replacement, Unsolder the Battery: adım 5, 2 resimden 1. HMDX Chill Battery Replacement, Unsolder the Battery: adım 5, 2 resimden 2.
    • Locate the wires that attaches from the battery to the motherboard.
    • Using a soldering iron desolder the wires from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jourdan Holubasch
759 İtibar
7 adet Kılavuz yazıldı
Ekip
EWU-Giguere-S16S1G1 EWU-Giguere-S16S1G1 üyesi
Community
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 694
