Giriş
If your HMDX Chill is having any kind of issue this guide will show how to disassemble the device in order to begin the process of fixing your issues.
Neye ihtiyacın var
Insert a metal spudger under the rubber base.
Pry the rubber base off.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
I have jam zero chill. One year old. Very very little use. Maybe 3 to 4 hours total.
Plug in to charge red light comes on solid and goes out in couple of hours. Then light flashes red and zero chill will not connect.
Thank you
