Ana içeriğe geç
HMDX Chill Front Buttons Replacement
Neye ihtiyacın var
    1. HMDX Chill Front Buttons Replacement, Remove Rubber Base: adım 1, 3 resimden 1. HMDX Chill Front Buttons Replacement, Remove Rubber Base: adım 1, 3 resimden 2. HMDX Chill Front Buttons Replacement, Remove Rubber Base: adım 1, 3 resimden 3.
      • Insert a metal spudger under the rubber base.
      • Pry the rubber base off.
      FixBot'a Sor
      Yorum Ekle
    2. HMDX Chill Front Buttons Replacement: adım 2, 1 resimden 1.
      • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
      FixBot'a Sor
      Yorum Ekle
    3. HMDX Chill Front Buttons Replacement: adım 3, 2 resimden 1. HMDX Chill Front Buttons Replacement: adım 3, 2 resimden 2.
      • Grip the base of the HMDX Chill.
      • Pull the base upwards.
      FixBot'a Sor
      Yorum Ekle
    1. HMDX Chill Front Buttons Replacement, Front Buttons: adım 4, 1 resimden 1.
      • Using a metal spudger, push the small latch upwards towards the button from the bottom of the base.
      • These are located underneath the rubber base, prior to removal.
      FixBot'a Sor
      Yorum Ekle
    2. HMDX Chill Front Buttons Replacement: adım 5, 2 resimden 1. HMDX Chill Front Buttons Replacement: adım 5, 2 resimden 2.
      • Insert a spudger into the slit between the bottom of the buttons and the speaker base.
      • Push the buttons upwards, away from the base, until they come loose.
      • Use your hand to pull the linked buttons off the base.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jourdan Holubasch
759 İtibar
7 adet Kılavuz yazıldı
Ekip
EWU-Giguere-S16S1G1 EWU-Giguere-S16S1G1 üyesi
Community
4 Üyeler
14 adet Kılavuz yazıldı
1Rehber Yorum
where can I buy new front buttons for replacement?
syanco_jim - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 27
Her zaman: 711
