Ana içeriğe geç
HMDX Jam Battery Replacement
Neye ihtiyacın var
    1. HMDX Jam Battery Replacement, Opening speaker: adım 1, 1 resimden 1.
      • Use the plastic opening tool to pry off the rubber cover at the bottom of the speaker.
      FixBot'a Sor
      Yorum Ekle
    2. HMDX Jam Battery Replacement, remove rubber cover: adım 2, 1 resimden 1.
      • Gently remove the rubber cover to expose the screws. If necessary, poke holes through the glue residue to expose the screw heads.
      FixBot'a Sor
      Yorum Ekle
    3. HMDX Jam Battery Replacement, Remove screws: adım 3, 1 resimden 1.
      • Once you have exposed the screws, use a #1 Phillips screwdriver to remove the four 9 mm screws.
      • It would be wise to use a magnetic mat for the screws for safekeeping.
      FixBot'a Sor
      Yorum Ekle
    4. HMDX Jam Battery Replacement, Exposing Battery: adım 4, 1 resimden 1.
      • Once you've removed the screws, open the case slowly. The battery is covered in blue packaging.
      FixBot'a Sor
      Yorum Ekle
    5. HMDX Jam Battery Replacement, Removing Battery: adım 5, 1 resimden 1.
      • Very gently remove the battery from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    6. HMDX Jam Battery Replacement, Remove battery attachments: adım 6, 2 resimden 1. HMDX Jam Battery Replacement, Remove battery attachments: adım 6, 2 resimden 2.
      • Use a solder gun to remove the battery attachments from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
42 farklı kişi bu kılavuzu tamamladı.
Ekip
USF Tampa, Team 1-1, Blackwell Winter 2015 USF Tampa, Team 1-1, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S1G1
4 Üyeler
4 adet Kılavuz yazıldı
18Kılavuz Yorumları
Looks like a great solution to fixing the speaker with a battery with a short life span. But what's the amperage of the lithium barberry and where can I purchase one ?
Stephen Lavizzo - Yanıt Paylaş
Did you ever find out where to purchase a new battery for it?
DJ Ethics - Yanıt Paylaş
Hey Stephen. Can you tell me where i can buy a replacement battery for my P120
Lynchfield Daniel - Yanıt Paylaş
On my Model: HX-P240A
KANYO 383541P 3.7V
520mAh 1.924Wh
534114364A17142
minhngoctruong - Yanıt Paylaş
My Bluetooth speaker just has a rubber suction on the bottom. There is no area to replace a battery. Is there any way to reset I?
bdale46 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 23
Son 30 gün: 105
Her zaman: 98,745
