Giriş
Outline what you are going to teach someone how to do.
Neye ihtiyacın var
Use the plastic opening tool to pry off the rubber cover at the bottom of the speaker.
Gently remove the rubber cover to expose the screws. If necessary, poke holes through the glue residue to expose the screw heads.
Once you have exposed the screws, use a #1 Phillips screwdriver to remove the four 9 mm screws.
Once you've removed the screws, open the case slowly. The battery is covered in blue packaging.
Very gently remove the battery from the motherboard.
Use a solder gun to remove the battery attachments from the motherboard.
Disculpa. Que modelo es esa batería?
Buenos días tengo un problema con una bocina jam se despegaron los cuatro cables y un conector
40 farklı kişi bu kılavuzu tamamladı.
18 Yorum
Looks like a great solution to fixing the speaker with a battery with a short life span. But what's the amperage of the lithium barberry and where can I purchase one ?
Did you ever find out where to purchase a new battery for it?
Hey Stephen. Can you tell me where i can buy a replacement battery for my P120
On my Model: HX-P240A
KANYO 383541P 3.7V
520mAh 1.924Wh
534114364A17142
Not sure if it is just mine or if this is actually how it charges. When I plug my HMDX Bluetooth earbuds, the light will turn red for a little bit then it turned off. Is it still charging or is something wrong with my earbuds?
No replies from the owner???wtf
Where do you buy the new battery
Instructions above were helpful for my HMDX Jam model HX-P230A. To replace the battery, I bought a 3.7V 550 mAh battery on eBay for $7.50. (I believe the original battery was 500 mAh). See eBay listing at http://www.ebay.com/itm/251453907013. There's no manufacturer but the UPC is 737590401657 and the Model number is 053035. I'm not a great solderer so I did not unsolder the old battery. Instead I clipped the leads about half way. I then twisted the new battery wires onto the wires dangling from the circuit board. BTW - the wires are really small. After twisting, I soldered the twisted wires and then wrapped with electrical tape. So far, works like new again. Good luck with your battery replacement!
do you think the battery will work with a HX-P30D or is it only HX-P30A
"What replacement battery?" (in general)
Two Parameters:
1) Voltage:
3.7V should normally the default voltage (V) of this build-in Lithium batteries. I suppose you could choose any other Lithium Battery, with the same voltage. To the best of my knowledge.
2) Ampere:
The origin battery of HX-P230A has ~500mA (=0.5A). You could also take a higher A (ampere) to prolong use-time.
I personal chose Battery “NB-6L” (3.7V, 1600mAh). The physical dimension of this battery are nearly perfect for HX-P230A.
Qual o modelo da bateria, a minha vem com dois fios a mais preto e verde além dos fios da bateria
My zero chill is only year old. No use at all. Red light comes on but unit will not turn on when I push the button. Is that battery? Thank you
