Ana içeriğe geç
HMDX Jam Plus Battery Replacement
Neye ihtiyacın var
  1. HMDX Jam Plus Battery Replacement, Battery: adım 1, 3 resimden 1. HMDX Jam Plus Battery Replacement, Battery: adım 1, 3 resimden 2. HMDX Jam Plus Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Flip the device over so the bottom is facing up.
    • Use the large plastic opening tool to gently pry the rubber base from the device.
    • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
  2. HMDX Jam Plus Battery Replacement: adım 2, 2 resimden 1. HMDX Jam Plus Battery Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
  3. HMDX Jam Plus Battery Replacement: adım 3, 2 resimden 1. HMDX Jam Plus Battery Replacement: adım 3, 2 resimden 2.
    • Gently separate the base from the rest of the device to reveal the battery and the main board.
  4. HMDX Jam Plus Battery Replacement: adım 4, 3 resimden 1. HMDX Jam Plus Battery Replacement: adım 4, 3 resimden 2. HMDX Jam Plus Battery Replacement: adım 4, 3 resimden 3.
    • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
    • Pull gently on the connectors to separate each one from the main board.
    • The battery is connected to board in the red socket and the speaker is connected in the white socket.
  5. HMDX Jam Plus Battery Replacement: adım 5, 3 resimden 1. HMDX Jam Plus Battery Replacement: adım 5, 3 resimden 2. HMDX Jam Plus Battery Replacement: adım 5, 3 resimden 3.
    • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
    • Use the plastic opening tool to gently pry the battery free from the rest of the device.
  6. HMDX Jam Plus Battery Replacement: adım 6, 2 resimden 1. HMDX Jam Plus Battery Replacement: adım 6, 2 resimden 2.
    • Use new adhesive to secure battery back to the rest of the device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Maxwell Erickson
587 İtibar
4 adet Kılavuz yazıldı
Ekip
Montana Tech, Team 10-3, Shirk Fall 2015 Montana Tech, Team 10-3, Shirk Fall 2015 üyesi
MTUM-SHIRK-F15S10G3
4 Üyeler
6 Yorum
Where may battery be purchased?
Thanks,
zappenfusen
warnsdorff - Yanıt
Where to purchase battery for hmdx jam speaker
Frank David -
Where can a battery be purchased?
robertwacker - Yanıt
What kind (especifications) that battery?
vecchio.farias - Yanıt
Where to buy battery for HMDX JAM.Bluetooth speaker
Frank David - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 37
Her zaman: 7,173
