Giriş
Sometimes speakers don't last as long as we need them too. This guide is to show the process of replacing a bad speaker in the HMDX Jam Plus. The replacement requires no special skills and is straightforward.
Neye ihtiyacın var
Flip the device over so the bottom is facing up.
Use the large plastic opening tool to gently pry the rubber base from the device.
Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
Use a Phillips #1 screwdriver to remove the four black 9mm screws from device.
Bir başkası bu kılavuzu tamamladı.
