Ana içeriğe geç
HP 10 2101 Battery Replacement
Neye ihtiyacın var
  1. HP 10 2101 Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Identify the SD card port.
  2. HP 10 2101 Battery Replacement: adım 2, 1 resimden 1.
    • Insert the smallest plastic opening tool into the SD card port. Gently pry until the back panel separates from the screen panel.
    • Do not insert opening tool too far. Avoid making contact with the metal inside the port.
  3. HP 10 2101 Battery Replacement: adım 3, 1 resimden 1.
    • Slide the opening tool along the seam between the back panel and the screen panel, prying the panels apart as you move around the edges.
  4. HP 10 2101 Battery Replacement: adım 4, 1 resimden 1.
    • Separate the back panel from the rest of the device.
  5. HP 10 2101 Battery Replacement, Battery: adım 5, 1 resimden 1.
    • Desolder the battery connectors from the motherboard.
  6. HP 10 2101 Battery Replacement: adım 6, 1 resimden 1.
    • Pull the bright blue-green tabs to remove the battery from the rest of the device.
    • Pulling the tabs may not fully disconnect the battery from the metal display casing.
  7. HP 10 2101 Battery Replacement: adım 7, 2 resimden 1. HP 10 2101 Battery Replacement: adım 7, 2 resimden 2.
    • If the previous step is unsuccessful, wedge the smallest plastic opening tool between the adhesive and the metal display casing.
    • Wedging may apply unsafe pressure on the battery. Be careful not to puncture the battery.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Do you know where to buy a replacement battery for this device?
Nathan Wells - Yanıt
Hi Nathan,
Unfortunately HP has not released this battery for sale to the public, as seen at https://parts.hp.com/hpparts/Search_Resu.... It may be worthwhile to contact HP. Here is an email address for their customer service: ''HPparts.sales.ams@hp.com.
Bryce Harmsen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 1,188
