Ana içeriğe geç
HP 10 2101 Microphone Replacement
Neye ihtiyacın var
  1. HP 10 2101 Microphone Replacement, Back Panel: adım 1, 1 resimden 1.
    • Identify the SD card port.
    FixBot'a Sor
    Yorum Ekle
  2. HP 10 2101 Microphone Replacement: adım 2, 1 resimden 1.
    • Insert the smallest plastic opening tool into the SD card port. Gently pry until the back panel separates from the screen panel.
    • Do not insert opening tool too far. Avoid making contact with the metal inside the port.
    FixBot'a Sor
    Yorum Ekle
  3. HP 10 2101 Microphone Replacement: adım 3, 1 resimden 1.
    • Slide the opening tool along the seam between the back panel and the screen panel, prying the panels apart as you move around the edges.
    FixBot'a Sor
    Yorum Ekle
  4. HP 10 2101 Microphone Replacement: adım 4, 1 resimden 1.
    • Separate the back panel from the rest of the device.
    FixBot'a Sor
    Yorum Ekle
  5. HP 10 2101 Microphone Replacement, Microphone: adım 5, 1 resimden 1.
    • Desolder the microphone wires from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. HP 10 2101 Microphone Replacement: adım 6, 1 resimden 1.
    • Separate the microphone from the rest of the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 23
Her zaman: 409
