Ana içeriğe geç
HP 14-ac151nr DC Power Jack Replacement
Neye ihtiyacın var
  1. HP 14-ac151nr DC Power Jack Replacement, Backplate: adım 1, 1 resimden 1.
    • Remove battery by pushing the two buttons inward.
  2. HP 14-ac151nr DC Power Jack Replacement: adım 2, 1 resimden 1.
    • Remove the two rubber feet next to the battery.
  3. HP 14-ac151nr DC Power Jack Replacement: adım 3, 1 resimden 1.
    • Remove all 14 Phillips head #0 screws.
  4. HP 14-ac151nr DC Power Jack Replacement: adım 4, 1 resimden 1.
    • Use a plastic opener tool to pry off the black backplate.
  5. HP 14-ac151nr DC Power Jack Replacement, DC Power Jack: adım 5, 2 resimden 1. HP 14-ac151nr DC Power Jack Replacement, DC Power Jack: adım 5, 2 resimden 2.
    • Remove the black tape near the power jack.
    • Remove the screws connecting monitor to the bottom of the computer.
  6. HP 14-ac151nr DC Power Jack Replacement: adım 6, 1 resimden 1.
    • Position the metal fittings attached to the monitor out of the way.
    • The monitor is still attached by wires — be careful not to pull on it too hard.
  7. HP 14-ac151nr DC Power Jack Replacement: adım 7, 3 resimden 1. HP 14-ac151nr DC Power Jack Replacement: adım 7, 3 resimden 2. HP 14-ac151nr DC Power Jack Replacement: adım 7, 3 resimden 3.
    • Disconnect the power jack from the motherboard.
    • Remove the power jack by lifting it up.
    • An opener tool may make this easier.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Antonio Leonti
410 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G7, Simcock Fall 2018 UMass Dartmouth, Team S1-G7, Simcock Fall 2018 üyesi
UMASSD-SIMCOCK-F18S1G7
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 434
