Giriş
This guide will aid in replacing the keys of the keyboard.
Parçalar
Hiçbir parçaya gerek yok.
  1. Use your prying tool to get under the key and gently pull it upwards to disengage the clips. Make sure the black scissor switch mechanism stays in place, as it is needed when putting the key back in (in second picture: the black piece surrounding the white plastic dome)
    • Use your prying tool to get under the key and gently pull it upwards to disengage the clips.
    • Make sure the black scissor switch mechanism stays in place, as it is needed when putting the key back in (in second picture: the black piece surrounding the white plastic dome)
  2. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
Sonuç
Brian Hall
85 İtibar
1 Kılavuz yazıldı
Takım
UMass Dartmouth, Team S1-G7, Simcock Fall 2018 UMass Dartmouth, Team S1-G7, Simcock Fall 2018 üyesi
UMASSD-SIMCOCK-F18S1G7
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 43
