Ana içeriğe geç
HP 14-am052nr Keyboard Replacement
Neye ihtiyacın var
  1. HP 14-am052nr Keyboard Replacement, Battery: adım 1, 3 resimden 1. HP 14-am052nr Keyboard Replacement, Battery: adım 1, 3 resimden 2. HP 14-am052nr Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • Turn the laptop over to its bottom so that the backside is facing you.
    • Using your fingers, push the two locking tabs inwards to release the battery.
    • Remove the battery from the device.
    FixBot'a Sor
    Yorum Ekle
  2. HP 14-am052nr Keyboard Replacement, Back Panel: adım 2, 2 resimden 1. HP 14-am052nr Keyboard Replacement, Back Panel: adım 2, 2 resimden 2.
    • After removing the battery with the laptop on its back, expose screws that are hidden under the rubber feet and the center label.
    • Using the Phillips #0 screwdriver, remove fourteen (14) 6 mm screws from the back panel.
    FixBot'a Sor
    Yorum Ekle
  3. HP 14-am052nr Keyboard Replacement: adım 3, 2 resimden 1. HP 14-am052nr Keyboard Replacement: adım 3, 2 resimden 2.
    • Use a prying tool to remove the back panel from the base of the computer.
    FixBot'a Sor
    Yorum Ekle
  4. HP 14-am052nr Keyboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove three 3 mm screws and five 3.5 mm screws from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  5. HP 14-am052nr Keyboard Replacement: adım 5, 2 resimden 1. HP 14-am052nr Keyboard Replacement: adım 5, 2 resimden 2.
    • Using the Phillips #0 screwdriver, remove four 1.5 mm screws from the silver cover.
    • Remove the silver cover from the device.
    FixBot'a Sor
    Yorum Ekle
  6. HP 14-am052nr Keyboard Replacement: adım 6, 3 resimden 1. HP 14-am052nr Keyboard Replacement: adım 6, 3 resimden 2. HP 14-am052nr Keyboard Replacement: adım 6, 3 resimden 3.
    • Unplug all connectors attached to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. HP 14-am052nr Keyboard Replacement: adım 7, 1 resimden 1.
    • Once all plugs and screws disconnected, remove the motherboard from the device.
    FixBot'a Sor
    Yorum Ekle
  8. HP 14-am052nr Keyboard Replacement, Keyboard: adım 8, 2 resimden 1. HP 14-am052nr Keyboard Replacement, Keyboard: adım 8, 2 resimden 2.
    • Carefully pry up the metal plate and detach it from the base.
    FixBot'a Sor
    Yorum Ekle
  9. HP 14-am052nr Keyboard Replacement: adım 9, 1 resimden 1.
    • Pull the plate away from the base while pulling the keyboard connecting cable through.
    FixBot'a Sor
    Yorum Ekle
  10. HP 14-am052nr Keyboard Replacement: adım 10, 2 resimden 1. HP 14-am052nr Keyboard Replacement: adım 10, 2 resimden 2.
    • Pull the keyboard out carefully from the base.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Corwin DeFeo
237 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-3, Sinclaire Fall 2021 UMass Dartmouth, Team 3-3, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S3G3
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 410
