Ana içeriğe geç
HP 14-am052nr RAM Replacement
Neye ihtiyacın var
  1. HP 14-am052nr RAM Replacement, Battery: adım 1, 3 resimden 1. HP 14-am052nr RAM Replacement, Battery: adım 1, 3 resimden 2. HP 14-am052nr RAM Replacement, Battery: adım 1, 3 resimden 3.
    • Turn the laptop over to its bottom so that the backside is facing you.
    • Using your fingers, push the two locking tabs inwards to release the battery.
    • Remove the battery from the device.
    FixBot'a Sor
    Yorum Ekle
  2. HP 14-am052nr RAM Replacement, Back Panel: adım 2, 2 resimden 1. HP 14-am052nr RAM Replacement, Back Panel: adım 2, 2 resimden 2.
    • After removing the battery with the laptop on its back, expose screws that are hidden under the rubber feet and the center label.
    • Using the Phillips #0 screwdriver, remove fourteen (14) 6 mm screws from the back panel.
    FixBot'a Sor
    Yorum Ekle
  3. HP 14-am052nr RAM Replacement: adım 3, 2 resimden 1. HP 14-am052nr RAM Replacement: adım 3, 2 resimden 2.
    • Use a prying tool to remove the back panel from the base of the computer.
    FixBot'a Sor
    Yorum Ekle
  4. HP 14-am052nr RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Push the two silver tabs on the sides of the RAM away from each other.
    • The RAM should now be loose and pointed upwards.
    FixBot'a Sor
    Yorum Ekle
  5. HP 14-am052nr RAM Replacement: adım 5, 1 resimden 1.
    • Gently lift and remove the RAM stick at a 45 degree angle from the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Matthew Heather
379 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-3, Sinclaire Fall 2021 UMass Dartmouth, Team 3-3, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S3G3
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 26
Her zaman: 549
