Giriş
In this replacement guide, we will be showing you how to remove the bottom panel of an HP 14-an012nr laptop. This guide will be applicable to a situation that involves needing access to the components within the device or if it's damaged like chipping or cracking. Caution should be exercised when removing the back panel as it will leave the components inside vulnerable.
Neye ihtiyacın var
Remove the eight 6 mm screws from the back panel using a Phillips #1 screwdriver.
Remove the rubber pads from the upper corners of the laptop to reveal two screws on each side.
Remove six 4 mm screws using a Phillips #1 screwdriver.
Pry the back panel off using an opening tool, working your way around the edges.
