Ana içeriğe geç
HP 14-an012nr RAM Replacement
Neye ihtiyacın var
  1. HP 14-an012nr RAM Replacement, Battery: adım 1, 3 resimden 1. HP 14-an012nr RAM Replacement, Battery: adım 1, 3 resimden 2. HP 14-an012nr RAM Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the battery by sliding both sliders inward.
  2. HP 14-an012nr RAM Replacement, Back Panel: adım 2, 3 resimden 1. HP 14-an012nr RAM Replacement, Back Panel: adım 2, 3 resimden 2. HP 14-an012nr RAM Replacement, Back Panel: adım 2, 3 resimden 3.
    • Remove the eight 6 mm screws from the back panel using a Phillips #1 screwdriver.
    • Remove the rubber pads from the upper corners of the laptop to reveal two screws on each side.
    • Remove six 4 mm screws using a Phillips #1 screwdriver.
    • Pry the back panel off using an opening tool, working your way around the edges.
  3. HP 14-an012nr RAM Replacement, RAM: adım 3, 3 resimden 1. HP 14-an012nr RAM Replacement, RAM: adım 3, 3 resimden 2. HP 14-an012nr RAM Replacement, RAM: adım 3, 3 resimden 3.
    • Push the two silver retaining arms apart at the same time.
    • As soon as the RAM pops out, remove it.
    • When removing or reinserting the RAM, be careful as to avoiding scratching or damaging the RAM.
Sonuç
Marvin lira
267 İtibar
3 adet Kılavuz yazıldı
Ekip
Gateway, Team 2-2, Gonzalez Fall 2023 Gateway, Team 2-2, Gonzalez Fall 2023 üyesi
GCC-GONZALEZ-F23S2G2
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 10
Her zaman: 82
