Giriş
To access the internal components of the HP 14-dq0051dx, you need to remove the outer panel on the bottom of the device. You'll need to remove the back case to for most repairs.
Before beginning this guide, power down the laptop and disconnect your device from the AC adapter.
Neye ihtiyacın var
Turn the laptop upside down so the backside is facing up.
Use a Phillips #1 screwdriver to remove eight screws from the back case.
Neredeyse bitti!
Sonuç
