Ana içeriğe geç
HP 14-dq0051dx Keyboard Replacement
Neye ihtiyacın var
  1. HP 14-dq0051dx Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. HP 14-dq0051dx Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Turn the laptop upside down so the backside is facing up.
    • Use a Phillips #1 screwdriver to remove eight 2.5mm screws from the back case.
  2. HP 14-dq0051dx Keyboard Replacement: adım 2, 1 resimden 1.
    • Turn the laptop over and open the screen.
    • Insert the opening tool into the seam between the bottom panel and the keyboard.
    • Run the opening tool along the entire seam to separate the bottom panel.
    • You may hear clicking as you release the taps that secure the case.
  3. HP 14-dq0051dx Keyboard Replacement: adım 3, 1 resimden 1.
    • Once the bottom panel is separated from the laptop, carefully close the laptop and turn it upside down.
    • Place both your hands on opposite ends of the bottom panel, and lift up and remove the panel.
  4. HP 14-dq0051dx Keyboard Replacement: adım 4, 3 resimden 1. HP 14-dq0051dx Keyboard Replacement: adım 4, 3 resimden 2. HP 14-dq0051dx Keyboard Replacement: adım 4, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the five 2.5 mm screws that secure the motherboard cover.
    • Remove the motherboard cover from the laptop.
  5. HP 14-dq0051dx Keyboard Replacement: adım 5, 3 resimden 1. HP 14-dq0051dx Keyboard Replacement: adım 5, 3 resimden 2. HP 14-dq0051dx Keyboard Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the four 2.5 mm screws that secure the battery.
    • Remove the battery from the laptop.
  6. HP 14-dq0051dx Keyboard Replacement: adım 6, 3 resimden 1. HP 14-dq0051dx Keyboard Replacement: adım 6, 3 resimden 2. HP 14-dq0051dx Keyboard Replacement: adım 6, 3 resimden 3.
    • Use the blue opening tool to flip up the small locking flap from the ZIF connector that attaches the touchpad cable to the motherboard.
    • Gently pull the ribbon cable out from the connector.
    • Ensure that the connector is pulled out gently as this is connector is very easy to damage
  7. HP 14-dq0051dx Keyboard Replacement: adım 7, 2 resimden 1. HP 14-dq0051dx Keyboard Replacement: adım 7, 2 resimden 2.
    • Gently unplug the keyboard connector from the motherboard.
  8. HP 14-dq0051dx Keyboard Replacement: adım 8, 3 resimden 1. HP 14-dq0051dx Keyboard Replacement: adım 8, 3 resimden 2. HP 14-dq0051dx Keyboard Replacement: adım 8, 3 resimden 3.
    • Lift up the small compartment with your finger.
    • Pull the flat cable out of the connector.
  9. HP 14-dq0051dx Keyboard Replacement: adım 9, 3 resimden 1. HP 14-dq0051dx Keyboard Replacement: adım 9, 3 resimden 2. HP 14-dq0051dx Keyboard Replacement: adım 9, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the single 1 mm screw that secure the WiFi card.
    • Pull the WiFi card out of its slot
    • Pull the WiFi card out slowly and gently as to not damage the card or the slot
  10. HP 14-dq0051dx Keyboard Replacement: adım 10, 2 resimden 1. HP 14-dq0051dx Keyboard Replacement: adım 10, 2 resimden 2.
    • Pull the charging port cable away from the connector in the same direction as the individual wires to unplug the charge port connector.
    • Remove the charging port.
  11. HP 14-dq0051dx Keyboard Replacement: adım 11, 2 resimden 1. HP 14-dq0051dx Keyboard Replacement: adım 11, 2 resimden 2.
    • Lift up the port using the blue opening tool.
    • Continue to lift up until it is unplugged from the motherboard.
  12. HP 14-dq0051dx Keyboard Replacement: adım 12, 2 resimden 1. HP 14-dq0051dx Keyboard Replacement: adım 12, 2 resimden 2.
    • Place both hands on opposite corners of the motherboard and carefully lift it up to remove it from the laptop.
    • Now the motherboard has been successfully removed and is ready to be replaced!
  13. HP 14-dq0051dx Keyboard Replacement: adım 13, 3 resimden 1. HP 14-dq0051dx Keyboard Replacement: adım 13, 3 resimden 2. HP 14-dq0051dx Keyboard Replacement: adım 13, 3 resimden 3.
    • Remove the two 2.5 mm screws that secure the motherboard cover using a Phillips #1 screwdriver.
    • Gently pull the component out of the laptop
  14. HP 14-dq0051dx Keyboard Replacement: adım 14, 3 resimden 1. HP 14-dq0051dx Keyboard Replacement: adım 14, 3 resimden 2. HP 14-dq0051dx Keyboard Replacement: adım 14, 3 resimden 3.
    • Remove the signle 2 mm screws that secure the side cover using a Phillips #0 screwdriver.
    • Pull the side cover off gently
  15. HP 14-dq0051dx Keyboard Replacement: adım 15, 3 resimden 1. HP 14-dq0051dx Keyboard Replacement: adım 15, 3 resimden 2. HP 14-dq0051dx Keyboard Replacement: adım 15, 3 resimden 3.
    • Remove the six 2.5 mm screws that secure the keyboard to its hinges using a Phillips #1 screwdriver.
    • Once unscrewed, pull the hinge tabs upward gently using your hands
  16. HP 14-dq0051dx Keyboard Replacement: adım 16, 1 resimden 1.
    • Place both hands on opposite corners of the keyboard and carefully lift it off the laptop
Sonuç
Akash
601 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-4, Harley Fall 2023 IUPUI, Team 2-4, Harley Fall 2023 üyesi
IUPUI-HARLEY-F23S2G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 98
