Giriş
Use this guide to replace the keyboard of your HP 14-dq0051dx laptop. Replacing this component may be required if it is damaged or not functional.
However, note that keyboard replacements are more complicated than individual key or touchpad repairs which should be attempted first before replacing the whole keyboard.
Before beginning this repair, turn your laptop off and unplug from the AC adapter.
Neye ihtiyacın var
Turn the laptop upside down so the backside is facing up.
Use a Phillips #1 screwdriver to remove eight 2.5mm screws from the back case.
