Ana içeriğe geç
HP 14-dq0051dx RAM Replacement
Neye ihtiyacın var
    1. HP 14-dq0051dx RAM Replacement, Back Case: adım 1, 2 resimden 1. HP 14-dq0051dx RAM Replacement, Back Case: adım 1, 2 resimden 2.
      • Turn the laptop upside down so the backside is facing up.
      • Use a Phillips #1 screwdriver to remove eight screws from the back case.
      FixBot'a Sor
      Yorum Ekle
    2. HP 14-dq0051dx RAM Replacement: adım 2, 1 resimden 1.
      • Turn the laptop over and open the screen.
      • Insert the opening tool into the seam between the bottom panel and the keyboard.
      • Run the opening tool along the entire seam to separate the bottom panel.
      • You may hear clicking as you release the taps that secure the case.
      FixBot'a Sor
      Yorum Ekle
    3. HP 14-dq0051dx RAM Replacement: adım 3, 1 resimden 1.
      • Once the bottom panel is separated from the laptop, carefully close the laptop and turn it upside down.
      • Place both your hands on opposite ends of the bottom panel, and lift up and remove the panel.
      FixBot'a Sor
      Yorum Ekle
    1. HP 14-dq0051dx RAM Replacement, Battery: adım 4, 3 resimden 1. HP 14-dq0051dx RAM Replacement, Battery: adım 4, 3 resimden 2. HP 14-dq0051dx RAM Replacement, Battery: adım 4, 3 resimden 3.
      • Use a Phillips #1 screwdriver to remove the four 2.5 mm screws that secure the battery.
      • Remove the battery from the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. HP 14-dq0051dx RAM Replacement, RAM: adım 5, 2 resimden 1. HP 14-dq0051dx RAM Replacement, RAM: adım 5, 2 resimden 2.
      • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it.
      • The RAM stick will pop up by a few millimeters.
      • Remove it at an angle and not straight up so you don't damage the socket.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Right on for the laptop assembly /disassembly blueprints
Brandon1 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 50
Her zaman: 1,835
