Ana içeriğe geç
HP 14-dq0052dx Motherboard Replacement
Neye ihtiyacın var
  1. HP 14-dq0052dx Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Orient your laptop so that the vents are facing upwards.
  2. HP 14-dq0052dx Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the rubber feet.
  3. HP 14-dq0052dx Motherboard Replacement: adım 3, 2 resimden 1. HP 14-dq0052dx Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the four M2.0 x 6 mm screws using a JIS #1 screwdriver.
    • Remove the two M2.5 x 6 mm screws using a JIS #1 screwdriver.
    • Remove the two M2.0 x 4 mm screws using a JIS #1 screwdriver.
    • Use an iFixit opening tool to pry the back cover away from the laptop.
  4. HP 14-dq0052dx Motherboard Replacement, Battery: adım 4, 1 resimden 1.
    • Unplug the battery from the motherboard.
    • Carefully pull back and raise the battery out of its slot.
    • Replace the battery.
  5. HP 14-dq0052dx Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove the five 4 mm screws from the heatsink.
  6. HP 14-dq0052dx Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the heatsink from the laptop.
  7. HP 14-dq0052dx Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the 4 mm screw from the bracket holding down the motherboard.
  8. HP 14-dq0052dx Motherboard Replacement: adım 8, 2 resimden 1. HP 14-dq0052dx Motherboard Replacement: adım 8, 2 resimden 2.
    • Lift up the retaining clip to access the ribbon cable attached to the motherboard.
    • Be careful when removing the ribbon cable as it is prone to ripping which will damage it.
    • Remove the ribbon cable from the motherboard
  9. HP 14-dq0052dx Motherboard Replacement: adım 9, 1 resimden 1.
    • Lift up this tab and remove the ribbon cable from the motherboard.
    • Be gentle with the ribbon cable as it can easily tear.
  10. HP 14-dq0052dx Motherboard Replacement: adım 10, 2 resimden 1. HP 14-dq0052dx Motherboard Replacement: adım 10, 2 resimden 2.
    • Remove the 4 mm screw from the Wi-Fi card.
    • Remove the Wi-Fi card from the motherboard.
  11. HP 14-dq0052dx Motherboard Replacement: adım 11, 2 resimden 1. HP 14-dq0052dx Motherboard Replacement: adım 11, 2 resimden 2.
    • Disconnect the small wires from the top of the motherboard.
    • Be extremely careful with these wires as bending them can cause the fragile inner wire to break.
  12. HP 14-dq0052dx Motherboard Replacement: adım 12, 1 resimden 1.
    • Carefully remove the motherboard.
Sonuç
DamianR
279 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-5, Konn Fall 2024 UMass Dartmouth, Team 2-5, Konn Fall 2024 üyesi
UMASSD-KONN-F24S2G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 18
Son 30 gün: 37
Her zaman: 115
