Ana içeriğe geç
HP 14-fq1025nr Screen Replacement
Neye ihtiyacın var
  1. HP 14-fq1025nr Screen Replacement, Back Cover: adım 1, 1 resimden 1.
    • Flip the laptop upside down so the bottom cover is facing up.
  2. HP 14-fq1025nr Screen Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a pair of tweezers to grab and pull the feet off of the cover.
  3. HP 14-fq1025nr Screen Replacement: adım 3, 1 resimden 1.
    • Remove the two 4 mm screws using a Phillips #0 screwdriver.
    • Remove the six remaining 6 mm screws located around the edges and underneath the feet using a Phillips #0 screwdriver.
  4. HP 14-fq1025nr Screen Replacement: adım 4, 1 resimden 1.
    • Flip the laptop right-side up and slide an iFixit opening tool and/or Jimmy inside of the bottom cover seam to pry it open.
  5. HP 14-fq1025nr Screen Replacement: adım 5, 1 resimden 1.
    • Remove the bottom cover.
  6. HP 14-fq1025nr Screen Replacement, Screen: adım 6, 3 resimden 1. HP 14-fq1025nr Screen Replacement, Screen: adım 6, 3 resimden 2. HP 14-fq1025nr Screen Replacement, Screen: adım 6, 3 resimden 3.
    • Remove the four black 5 mm screws holding down the two silver screen hinges using a Phillips #00 screwdriver.
  7. HP 14-fq1025nr Screen Replacement: adım 7, 2 resimden 1. HP 14-fq1025nr Screen Replacement: adım 7, 2 resimden 2.
    • Unplug the screen from the motherboard by lifting the wire cover and removing the screen cord.
    • Separate the hinges from the computer.
  8. HP 14-fq1025nr Screen Replacement: adım 8, 1 resimden 1.
    • Remove the screen.
Sonuç
Yasli Kanimba Murenzi
193 İtibar
2 adet Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-6, McMurrin Fall 2022 Utah Tech University, Team 1-6, McMurrin Fall 2022 üyesi
UTAHTECH-MCMURRIN-F22S1G6
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 300
