Ana içeriğe geç
HP 14-r008la Hard Disk Replacement
Neye ihtiyacın var
  1. HP 14-r008la Hard Disk Replacement, Hard Disk: adım 1, 3 resimden 1. HP 14-r008la Hard Disk Replacement, Hard Disk: adım 1, 3 resimden 2. HP 14-r008la Hard Disk Replacement, Hard Disk: adım 1, 3 resimden 3.
    • Shutdown the computer and remove the battery
    • Turn it right-side down, print a picture of its back cover
  2. HP 14-r008la Hard Disk Replacement, Removing screws: adım 2, 3 resimden 1. HP 14-r008la Hard Disk Replacement, Removing screws: adım 2, 3 resimden 2. HP 14-r008la Hard Disk Replacement, Removing screws: adım 2, 3 resimden 3.
    • Use double-sided tape to stick all the screws in its right place on the printed picture
    • Under the ram cover there is a screw, remove it
    • Dvd reader will come off when you remove its screw
    • Remove the two screws under the DVD reader
  3. HP 14-r008la Hard Disk Replacement, Removing rubber feet and Keyboard: adım 3, 3 resimden 1. HP 14-r008la Hard Disk Replacement, Removing rubber feet and Keyboard: adım 3, 3 resimden 2. HP 14-r008la Hard Disk Replacement, Removing rubber feet and Keyboard: adım 3, 3 resimden 3.
    • Remove the two rubber feet beside battery place
    • Turn the laptop right-side up and open and insert a pry tool along the top-side keyboard until release it
    • Release the connector to which the keyboard cable is attached, and then disconnect the keyboard cable.
  4. HP 14-r008la Hard Disk Replacement, Remove mother board cover: adım 4, 3 resimden 1. HP 14-r008la Hard Disk Replacement, Remove mother board cover: adım 4, 3 resimden 2. HP 14-r008la Hard Disk Replacement, Remove mother board cover: adım 4, 3 resimden 3.
    • Remove three screws under keyboard
    • Don't forget the security protocol we followed in step 1 and 2
    • Insert pry tool around the cover in which touchpad used to be until release
    • First release the left side because the right has a clips which hold the cover.
  5. HP 14-r008la Hard Disk Replacement, Remove HDD and insert another one: adım 5, 3 resimden 1. HP 14-r008la Hard Disk Replacement, Remove HDD and insert another one: adım 5, 3 resimden 2. HP 14-r008la Hard Disk Replacement, Remove HDD and insert another one: adım 5, 3 resimden 3.
    • Release the connector to which the cable of two usb ports has been attaching
    • Remove the two usb ports and the speaker, and the two HDD screws then pull the HDD off
    • Remove metal frame in the first HDD and put it in the second
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Internet Libre
718 İtibar
5 adet Kılavuz yazıldı
Bir Yorum
Good job it did not work
Susan Oginni - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 18
Her zaman: 4,824
