Ana içeriğe geç
HP 15-AF131DX Hard Drive Replacement
Neye ihtiyacın var
  1. HP 15-AF131DX Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. HP 15-AF131DX Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 10 visible screws on the bottom.
    • Peel up the rubber feet near the hinges.
    • Remove the screw under each.
  2. HP 15-AF131DX Hard Drive Replacement: adım 2, 2 resimden 1. HP 15-AF131DX Hard Drive Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Turn the computer over and use a plastic card, opening pick, or opening tool to pry the space between the keyboard and bottom surface of the computer.
    • Work plastic card, opening pick, or opening tool carefully around the three edges (excluding the side with the screen, which should be positioned at 90 degrees.
    • Gently lift the top surface of the bottom half of the laptop, revealing the hard drive.
  3. HP 15-AF131DX Hard Drive Replacement: adım 3, 3 resimden 1. HP 15-AF131DX Hard Drive Replacement: adım 3, 3 resimden 2. HP 15-AF131DX Hard Drive Replacement: adım 3, 3 resimden 3.
    • Remove the three screws that hold the hard drive in place.
    • Lift the hard drive slightly and disconnect the SATA hard drive connector to free the hard drive.
    • Remove the hard drive.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Anthony Martinez
526 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S6-G2, Banghart Fall 2017 Cal Poly, Team S6-G2, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S6G2
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 10
Son 30 gün: 36
Her zaman: 5,640
