Ana içeriğe geç
HP 15-AF131DX Optical Drive Replacement
Neye ihtiyacın var
  1. HP 15-AF131DX Optical Drive Replacement, Optical Drive: adım 1, 2 resimden 1. HP 15-AF131DX Optical Drive Replacement, Optical Drive: adım 1, 2 resimden 2.
    • Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
    • Pull the CD/DVD drive outward to slide it away from the computer.
  2. HP 15-AF131DX Optical Drive Replacement: adım 2, 1 resimden 1.
    • To open the drive use an unbent paperclip and press it into the small hole until the disc tray releases.
    • Pull the disc tray out from the front until it is as far as it will go out of the optical drive.
  3. HP 15-AF131DX Optical Drive Replacement: adım 3, 3 resimden 1. HP 15-AF131DX Optical Drive Replacement: adım 3, 3 resimden 2. HP 15-AF131DX Optical Drive Replacement: adım 3, 3 resimden 3.
    • To remove excess parts from the optical drive press down on the plastic tab behind the tray's bezel.
    • Gently pry the bezel from the face of the optical drive.
    • With a smaller phillips head screwdriver, remove the screws on the back of the drive, then remove the small metal bracket.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Aaron McCallister
134 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S6-G2, Banghart Fall 2017 Cal Poly, Team S6-G2, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S6G2
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 592
