Ana içeriğe geç
HP 15-AF131DX Trackpad Button Circuit Board Replacement
Neye ihtiyacın var
  1. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Battery: adım 1, 2 resimden 1. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the computer upside down on a level surface.
    • Slide the battery lock to unlock the battery.
    • Slide the battery release latch. The latch will click when the battery is released.
    • Lift the battery from the middle to remove it from the computer.
    • The latch will click again when a battery is reinstalled. Switch the battery lock back to locked after reinstalling a battery to keep it secure.
  2. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Optical Drive: adım 2, 2 resimden 1. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Optical Drive: adım 2, 2 resimden 2.
    • Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
    • Pull the CD/DVD drive outward to slide it away from the computer.
  3. HP 15-AF131DX Trackpad Button Circuit Board Replacement: adım 3, 1 resimden 1.
    • To open the drive use an unbent paperclip and press it into the small hole until the disc tray releases.
    • Pull the disc tray out from the front until it is as far as it will go out of the optical drive.
  4. HP 15-AF131DX Trackpad Button Circuit Board Replacement: adım 4, 3 resimden 1. HP 15-AF131DX Trackpad Button Circuit Board Replacement: adım 4, 3 resimden 2. HP 15-AF131DX Trackpad Button Circuit Board Replacement: adım 4, 3 resimden 3.
    • To remove excess parts from the optical drive press down on the plastic tab behind the tray's bezel.
    • Gently pry the bezel from the face of the optical drive.
    • With a smaller phillips head screwdriver, remove the screws on the back of the drive, then remove the small metal bracket.
  5. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Trackpad Button Circuit Board: adım 5, 2 resimden 1. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Trackpad Button Circuit Board: adım 5, 2 resimden 2.
    • Remove two rubber feet by peeling them off.
    • Remove twelve Phillips head 8.8mm screws using the Phillips #0 Screwdriver.
  6. HP 15-AF131DX Trackpad Button Circuit Board Replacement: adım 6, 3 resimden 1. HP 15-AF131DX Trackpad Button Circuit Board Replacement: adım 6, 3 resimden 2. HP 15-AF131DX Trackpad Button Circuit Board Replacement: adım 6, 3 resimden 3.
    • Remove the bottom of the plastic case using a blue plastic opening tool.
    • The Trackpad Button Circuit Board is found in the red box.
  7. HP 15-AF131DX Trackpad Button Circuit Board Replacement: adım 7, 2 resimden 1. HP 15-AF131DX Trackpad Button Circuit Board Replacement: adım 7, 2 resimden 2.
    • Remove the two 3.3mm Phillips-head screws that secure the trackpad circuit board to the top cover.
  8. HP 15-AF131DX Trackpad Button Circuit Board Replacement: adım 8, 2 resimden 1. HP 15-AF131DX Trackpad Button Circuit Board Replacement: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Lift the plastic wire lock bracket.
    • Pull on the blue tab to remove the wire using the tweezers tool to make sure there is no damage as you pull.
  9. HP 15-AF131DX Trackpad Button Circuit Board Replacement: adım 9, 2 resimden 1. HP 15-AF131DX Trackpad Button Circuit Board Replacement: adım 9, 2 resimden 2.
    • Lift the second plastic wire lock bracket.
    • Pull on the purple tab using tweezers to remove the wire.
  10. HP 15-AF131DX Trackpad Button Circuit Board Replacement: adım 10, 1 resimden 1.
    • Lift and remove the trackpad button circuit board.
Sonuç
Adrianna
133 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Harley Fall 2018 IUPUI, Team S2-G2, Harley Fall 2018 üyesi
IUPUI-HARLEY-F18S2G2
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 350
