Giriş
Before starting the steps outlined in this guide please have the battery and the CD/DVD optical drive removed.
Neye ihtiyacın var
Turn the computer upside down on a level surface.
Slide the battery lock to unlock the battery.
Slide the battery release latch. The latch will click when the battery is released.
Lift the battery from the middle to remove it from the computer.
Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
Pull the CD/DVD drive outward to slide it away from the computer.
The first step of this process is to peel off two rubber feet from the bottom of the laptop.
Then remove twelve 8.8 mm screws using the Phillips #0 Screwdriver.
Bir başkası bu kılavuzu tamamladı.
