Ana içeriğe geç
HP 15-AF131DX Wireless Network Card Replacement
Neye ihtiyacın var
  1. HP 15-AF131DX Wireless Network Card Replacement, Battery: adım 1, 2 resimden 1. HP 15-AF131DX Wireless Network Card Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the computer upside down on a level surface.
    • Slide the battery lock to unlock the battery.
    • Slide the battery release latch. The latch will click when the battery is released.
    • Lift the battery from the middle to remove it from the computer.
    • The latch will click again when a battery is reinstalled. Switch the battery lock back to locked after reinstalling a battery to keep it secure.
  2. HP 15-AF131DX Wireless Network Card Replacement, Optical Drive: adım 2, 2 resimden 1. HP 15-AF131DX Wireless Network Card Replacement, Optical Drive: adım 2, 2 resimden 2.
    • Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
    • Pull the CD/DVD drive outward to slide it away from the computer.
  3. HP 15-AF131DX Wireless Network Card Replacement: adım 3, 1 resimden 1.
    • To open the drive use an unbent paperclip and press it into the small hole until the disc tray releases.
    • Pull the disc tray out from the front until it is as far as it will go out of the optical drive.
  4. HP 15-AF131DX Wireless Network Card Replacement: adım 4, 3 resimden 1. HP 15-AF131DX Wireless Network Card Replacement: adım 4, 3 resimden 2. HP 15-AF131DX Wireless Network Card Replacement: adım 4, 3 resimden 3.
    • To remove excess parts from the optical drive press down on the plastic tab behind the tray's bezel.
    • Gently pry the bezel from the face of the optical drive.
    • With a smaller phillips head screwdriver, remove the screws on the back of the drive, then remove the small metal bracket.
  5. HP 15-AF131DX Wireless Network Card Replacement, Wireless Network Card: adım 5, 2 resimden 1. HP 15-AF131DX Wireless Network Card Replacement, Wireless Network Card: adım 5, 2 resimden 2.
    • The first step of this process is to peel off two rubber feet from the bottom of the laptop.
    • Then remove twelve 8.8 mm screws using the Phillips #0 Screwdriver.
  6. HP 15-AF131DX Wireless Network Card Replacement: adım 6, 3 resimden 1. HP 15-AF131DX Wireless Network Card Replacement: adım 6, 3 resimden 2. HP 15-AF131DX Wireless Network Card Replacement: adım 6, 3 resimden 3.
    • Remove the bottom of the plastic case using a blue plastic opening tool.
    • The HP Wireless Network Card is found in Picture 3, circled in red.
  7. HP 15-AF131DX Wireless Network Card Replacement: adım 7, 3 resimden 1. HP 15-AF131DX Wireless Network Card Replacement: adım 7, 3 resimden 2. HP 15-AF131DX Wireless Network Card Replacement: adım 7, 3 resimden 3.
    • Remove one 3.3 mm screw using Phillips #0 screwdriver.
    • Pop off the connection wire by pulling the wire upwards off the stud on the HP Wireless Network Card.
    • Pull out the HP Wireless Network Card.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Clayton Mettert
121 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Harley Fall 2018 IUPUI, Team S2-G2, Harley Fall 2018 üyesi
IUPUI-HARLEY-F18S2G2
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 599
