Ana içeriğe geç
HP 15-BA078DX Hard Drive Replacement
Neye ihtiyacın var
    1. HP 15-BA078DX Hard Drive Replacement, Battery: adım 1, 3 resimden 1. HP 15-BA078DX Hard Drive Replacement, Battery: adım 1, 3 resimden 2. HP 15-BA078DX Hard Drive Replacement, Battery: adım 1, 3 resimden 3.
      • Unclip the two latches on the bottom of the laptop.
      • Slide the battery straight out while holding the clip open.
      FixBot'a Sor
      Yorum Ekle
    1. HP 15-BA078DX Hard Drive Replacement, Disc Drive: adım 2, 1 resimden 1.
      • Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
      FixBot'a Sor
      Yorum Ekle
    2. HP 15-BA078DX Hard Drive Replacement: adım 3, 3 resimden 1. HP 15-BA078DX Hard Drive Replacement: adım 3, 3 resimden 2. HP 15-BA078DX Hard Drive Replacement: adım 3, 3 resimden 3.
      • Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    1. HP 15-BA078DX Hard Drive Replacement, Back Panel: adım 4, 1 resimden 1.
      • Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
      • Remember to remove the two screws under the rubber feet.
      FixBot'a Sor
      Yorum Ekle
    2. HP 15-BA078DX Hard Drive Replacement: adım 5, 3 resimden 1. HP 15-BA078DX Hard Drive Replacement: adım 5, 3 resimden 2. HP 15-BA078DX Hard Drive Replacement: adım 5, 3 resimden 3.
      • Carefully use the blue plastic opening tool to pry the clam shell of the laptop apart.
      • You may need to flip the laptop over to unlatch all of the internal clips.
      FixBot'a Sor
      Yorum Ekle
    3. HP 15-BA078DX Hard Drive Replacement: adım 6, 3 resimden 1. HP 15-BA078DX Hard Drive Replacement: adım 6, 3 resimden 2. HP 15-BA078DX Hard Drive Replacement: adım 6, 3 resimden 3.
      • Carefully pull the shell of the computer apart.
      FixBot'a Sor
      Yorum Ekle
    1. HP 15-BA078DX Hard Drive Replacement, Hard Drive: adım 7, 2 resimden 1. HP 15-BA078DX Hard Drive Replacement, Hard Drive: adım 7, 2 resimden 2.
      • Using a black nylon spudger, disconnect the black connector that attaches the hard drive to the motherboard
      FixBot'a Sor
      Yorum Ekle
    2. HP 15-BA078DX Hard Drive Replacement: adım 8, 1 resimden 1.
      • Using the Phillips #0 screwdriver, unscrew the three screws holding the hard drive down to the board.
      FixBot'a Sor
      Yorum Ekle
    3. HP 15-BA078DX Hard Drive Replacement: adım 9, 3 resimden 1. HP 15-BA078DX Hard Drive Replacement: adım 9, 3 resimden 2. HP 15-BA078DX Hard Drive Replacement: adım 9, 3 resimden 3.
      • Remove the hard drive.
      FixBot'a Sor
      Yorum Ekle
    4. HP 15-BA078DX Hard Drive Replacement: adım 10, 2 resimden 1. HP 15-BA078DX Hard Drive Replacement: adım 10, 2 resimden 2.
      • Using the Phillips #0 screwdriver, unscrew the four screws from the holding apparatus.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Benjamin DosSantos Jr
469 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G4, Peak Spring 2018 UMass Dartmouth, Team S3-G4, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G4
3 Üyeler
30 adet Kılavuz yazıldı
3Kılavuz Yorumları
Can you provide the HDD model number for replacement? Also the model number or description of a compatible HDD with higher capacity.
Thank You
jcoengineer - Yanıt Paylaş
Today, while disassembling my HP 15-BA078DX I had an issue trying to get the shell apart. I didn't realize that there was a screw under each rubber foot by the hinges. It would have saved me a whole lot of trouble had I known that. Very important to get those 2 screws out, otherwise you will risk breaking out the corner on the backside of the keyboard tray....... like I did. Fortunately for me, I was able to use some 2-part epoxy (the kind that works on plastic) to glue the hinge back down to the shell. Had the author pointed out those 2 screws in particular, in the pictorial, things would have gone way easier. Hopefully, this will help the next guy.
Eric S - Yanıt Paylaş
btw.........you will also need a #1 phillips screwdriver if you plan on removing the hard drive.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 1,636
