Ana içeriğe geç
HP 15-BA078DX RAM Replacement
Neye ihtiyacın var
  1. HP 15-BA078DX RAM Replacement, Battery: adım 1, 3 resimden 1. HP 15-BA078DX RAM Replacement, Battery: adım 1, 3 resimden 2. HP 15-BA078DX RAM Replacement, Battery: adım 1, 3 resimden 3.
    • Unclip the two latches on the bottom of the laptop.
    • Slide the battery straight out while holding the clip open.
    FixBot'a Sor
    Yorum Ekle
  2. HP 15-BA078DX RAM Replacement, Disc Drive: adım 2, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
    FixBot'a Sor
    Yorum Ekle
  3. HP 15-BA078DX RAM Replacement: adım 3, 3 resimden 1. HP 15-BA078DX RAM Replacement: adım 3, 3 resimden 2. HP 15-BA078DX RAM Replacement: adım 3, 3 resimden 3.
    • Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  4. HP 15-BA078DX RAM Replacement, Back Panel: adım 4, 1 resimden 1.
    • Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
    • Remember to remove the two screws under the rubber feet.
    FixBot'a Sor
    Yorum Ekle
  5. HP 15-BA078DX RAM Replacement: adım 5, 3 resimden 1. HP 15-BA078DX RAM Replacement: adım 5, 3 resimden 2. HP 15-BA078DX RAM Replacement: adım 5, 3 resimden 3.
    • Carefully use the blue plastic opening tool to pry the clam shell of the laptop apart.
    • You may need to flip the laptop over to unlatch all of the internal clips.
    FixBot'a Sor
    Yorum Ekle
  6. HP 15-BA078DX RAM Replacement: adım 6, 3 resimden 1. HP 15-BA078DX RAM Replacement: adım 6, 3 resimden 2. HP 15-BA078DX RAM Replacement: adım 6, 3 resimden 3.
    • Carefully pull the shell of the computer apart.
    FixBot'a Sor
    Yorum Ekle
  7. HP 15-BA078DX RAM Replacement, RAM: adım 7, 2 resimden 1. HP 15-BA078DX RAM Replacement, RAM: adım 7, 2 resimden 2.
    • Using a plastic spudger, unclip the latch locking the RAM to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. HP 15-BA078DX RAM Replacement: adım 8, 3 resimden 1. HP 15-BA078DX RAM Replacement: adım 8, 3 resimden 2. HP 15-BA078DX RAM Replacement: adım 8, 3 resimden 3.
    • Gently tilt the RAM sticks up and slide out each stick.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Benjamin DosSantos Jr
469 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G4, Peak Spring 2018 UMass Dartmouth, Team S3-G4, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G4
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 818
