Ana içeriğe geç
HP 15-BA078DX Touchscreen Replacement
Neye ihtiyacın var
  1. HP 15-BA078DX Touchscreen Replacement, Battery: adım 1, 3 resimden 1. HP 15-BA078DX Touchscreen Replacement, Battery: adım 1, 3 resimden 2. HP 15-BA078DX Touchscreen Replacement, Battery: adım 1, 3 resimden 3.
    • Unclip the two latches on the bottom of the laptop.
    • Slide the battery straight out while holding the clip open.
    FixBot'a Sor
    Yorum Ekle
  2. HP 15-BA078DX Touchscreen Replacement, Touchscreen: adım 2, 3 resimden 1. HP 15-BA078DX Touchscreen Replacement, Touchscreen: adım 2, 3 resimden 2. HP 15-BA078DX Touchscreen Replacement, Touchscreen: adım 2, 3 resimden 3.
    • Carefully use the blue plastic opening tool to remove the outer frame of the screen.
    FixBot'a Sor
    Yorum Ekle
  3. HP 15-BA078DX Touchscreen Replacement: adım 3, 3 resimden 1. HP 15-BA078DX Touchscreen Replacement: adım 3, 3 resimden 2. HP 15-BA078DX Touchscreen Replacement: adım 3, 3 resimden 3.
    • Flip the laptop on its back.
    • Detach the bottom section of the screen frame from the laptop by using the black nylon spudger.
    FixBot'a Sor
    Yorum Ekle
  4. HP 15-BA078DX Touchscreen Replacement: adım 4, 1 resimden 1.
    • Separate the frame from the screen.
    FixBot'a Sor
    Yorum Ekle
  5. HP 15-BA078DX Touchscreen Replacement: adım 5, 3 resimden 1. HP 15-BA078DX Touchscreen Replacement: adım 5, 3 resimden 2. HP 15-BA078DX Touchscreen Replacement: adım 5, 3 resimden 3.
    • Using the Phillips #0 screwdriver, unscrew the 4 screws around the frame.
    FixBot'a Sor
    Yorum Ekle
  6. HP 15-BA078DX Touchscreen Replacement: adım 6, 3 resimden 1. HP 15-BA078DX Touchscreen Replacement: adım 6, 3 resimden 2. HP 15-BA078DX Touchscreen Replacement: adım 6, 3 resimden 3.
    • Remove the touchscreen from the laptop.
    • Be careful not to damage the screen connector located at the bottom of the screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matthew Moore
341 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G4, Peak Spring 2018 UMass Dartmouth, Team S3-G4, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G4
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 30
Her zaman: 754
