Ana içeriğe geç
HP 15-R011DX Hard Drive Replacement
Neye ihtiyacın var
    1. HP 15-R011DX Hard Drive Replacement, Battery: adım 1, 2 resimden 1. HP 15-R011DX Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
      • Slide the lock mechanism on the left side of the laptop to the right.
      FixBot'a Sor
      Yorum Ekle
    2. HP 15-R011DX Hard Drive Replacement: adım 2, 1 resimden 1.
      • While holding the right slide mechanism, remove the battery from the laptop.
      • The battery is not pictured here because it is missing from this particular device.
      FixBot'a Sor
      Yorum Ekle
    1. HP 15-R011DX Hard Drive Replacement, How to Access the Internal Components of an HP 15-R011DX: adım 3, 2 resimden 1. HP 15-R011DX Hard Drive Replacement, How to Access the Internal Components of an HP 15-R011DX: adım 3, 2 resimden 2.
      • Flip the laptop over to reveal screw locations.
      • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
      FixBot'a Sor
      Yorum Ekle
    2. HP 15-R011DX Hard Drive Replacement: adım 4, 2 resimden 1. HP 15-R011DX Hard Drive Replacement: adım 4, 2 resimden 2.
      • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
      FixBot'a Sor
      Yorum Ekle
    3. HP 15-R011DX Hard Drive Replacement: adım 5, 2 resimden 1. HP 15-R011DX Hard Drive Replacement: adım 5, 2 resimden 2.
      • Remove the DVD drive from the laptop.
      • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
      FixBot'a Sor
      Yorum Ekle
    4. HP 15-R011DX Hard Drive Replacement: adım 6, 3 resimden 1. HP 15-R011DX Hard Drive Replacement: adım 6, 3 resimden 2. HP 15-R011DX Hard Drive Replacement: adım 6, 3 resimden 3.
      • Flip the laptop and open.
      • Detach the keyboard by prying it free from the laptop using a spudger.
      • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
      • Disconnect the keyboard ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    5. HP 15-R011DX Hard Drive Replacement: adım 7, 2 resimden 1. HP 15-R011DX Hard Drive Replacement: adım 7, 2 resimden 2.
      • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
      • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
      • Pry open the plastic casing using a spudger.
      • If struggling to remove the plastic case, check that all screws have been removed.
      FixBot'a Sor
      Yorum Ekle
    1. HP 15-R011DX Hard Drive Replacement, Hard Drive: adım 8, 1 resimden 1.
      • Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
      FixBot'a Sor
      Yorum Ekle
    2. HP 15-R011DX Hard Drive Replacement: adım 9, 2 resimden 1. HP 15-R011DX Hard Drive Replacement: adım 9, 2 resimden 2.
      • Pull the hard drive upwards and away from the laptop.
      • The hard drive should disconnect from its port on the motherboard as shown in the second image.
      FixBot'a Sor
      Yorum Ekle
    3. HP 15-R011DX Hard Drive Replacement: adım 10, 1 resimden 1.
      • Flip the hard drive over.
      • Remove the two 4 mm Phillips #1 screws from the base of the hard drive.
      • Remove the mounting brace (silver bracket) from the hard drive.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ethan Guillotte
517 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G4, Bailey Spring 2019 UMass Dartmouth, Team S2-G4, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S2G4
3 Üyeler
66 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 35
Her zaman: 1,880
