Ana içeriğe geç
HP 15-R011DX Motherboard Replacement
Neye ihtiyacın var
  1. HP 15-R011DX Motherboard Replacement, Battery: adım 1, 2 resimden 1. HP 15-R011DX Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the lock mechanism on the left side of the laptop to the right.
  2. HP 15-R011DX Motherboard Replacement: adım 2, 1 resimden 1.
    • While holding the right slide mechanism, remove the battery from the laptop.
    • The battery is not pictured here because it is missing from this particular device.
  3. HP 15-R011DX Motherboard Replacement, How to Access the Internal Components of an HP 15-R011DX: adım 3, 2 resimden 1. HP 15-R011DX Motherboard Replacement, How to Access the Internal Components of an HP 15-R011DX: adım 3, 2 resimden 2.
    • Flip the laptop over to reveal screw locations.
    • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
  4. HP 15-R011DX Motherboard Replacement: adım 4, 2 resimden 1. HP 15-R011DX Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
  5. HP 15-R011DX Motherboard Replacement: adım 5, 2 resimden 1. HP 15-R011DX Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove the DVD drive from the laptop.
    • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
  6. HP 15-R011DX Motherboard Replacement: adım 6, 3 resimden 1. HP 15-R011DX Motherboard Replacement: adım 6, 3 resimden 2. HP 15-R011DX Motherboard Replacement: adım 6, 3 resimden 3.
    • Flip the laptop and open.
    • Detach the keyboard by prying it free from the laptop using a spudger.
    • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
    • Disconnect the keyboard ribbon cable.
  7. HP 15-R011DX Motherboard Replacement: adım 7, 2 resimden 1. HP 15-R011DX Motherboard Replacement: adım 7, 2 resimden 2.
    • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
    • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
    • Pry open the plastic casing using a spudger.
    • If struggling to remove the plastic case, check that all screws have been removed.
  8. HP 15-R011DX Motherboard Replacement, Hard Drive: adım 8, 1 resimden 1.
    • Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
  9. HP 15-R011DX Motherboard Replacement: adım 9, 2 resimden 1. HP 15-R011DX Motherboard Replacement: adım 9, 2 resimden 2.
    • Pull the hard drive upwards and away from the laptop.
    • The hard drive should disconnect from its port on the motherboard as shown in the second image.
  10. HP 15-R011DX Motherboard Replacement: adım 10, 1 resimden 1.
    • Flip the hard drive over.
    • Remove the two 4 mm Phillips #1 screws from the base of the hard drive.
    • Remove the mounting brace (silver bracket) from the hard drive.
  11. HP 15-R011DX Motherboard Replacement, Motherboard: adım 11, 2 resimden 1. HP 15-R011DX Motherboard Replacement, Motherboard: adım 11, 2 resimden 2.
    • Remove the remaining two 5 mm Philips #1 screws from the motherboard.
  12. HP 15-R011DX Motherboard Replacement: adım 12, 1 resimden 1.
    • Remove the tape from the display connector attached to the motherboard.
    • Disconnect the display connector from the motherboard.
  13. HP 15-R011DX Motherboard Replacement: adım 13, 1 resimden 1.
    • Remove one 4 mm Phillips #1 screw from the wireless chip.
    • Remove the wireless chip from the motherboard.
  14. HP 15-R011DX Motherboard Replacement: adım 14, 1 resimden 1.
    • Remove two 5 mm Phillips #1 screws from the USB component connected to the motherboard.
    • Lift the USB component until the band connecting it to the motherboard lifts off of the laptop.
  15. HP 15-R011DX Motherboard Replacement: adım 15, 1 resimden 1.
    • Slowly lift the motherboard out of the computer.
    • Be sure that the I/O ports on the left side of the motherboard are not stuck on the laptop frame.
    • Disconnect the power connector from the motherboard as shown in the image.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ethan Guillotte
517 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G4, Bailey Spring 2019 UMass Dartmouth, Team S2-G4, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S2G4
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 583
