Ana içeriğe geç
HP 15-R263DX Disassembly
Neye ihtiyacın var
  1. HP 15-R263DX Disassembly, Battery: adım 1, 2 resimden 1. HP 15-R263DX Disassembly, Battery: adım 1, 2 resimden 2.
    • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
    • Slide the battery out as shown in the picture.
    FixBot'a Sor
    Yorum Ekle
  2. HP 15-R263DX Disassembly, Optical Drive: adım 2, 2 resimden 1. HP 15-R263DX Disassembly, Optical Drive: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
    FixBot'a Sor
    Yorum Ekle
  3. HP 15-R263DX Disassembly: adım 3, 1 resimden 1.
    • Gently slide the optical drive out of the side of the computer.
    FixBot'a Sor
    Yorum Ekle
  4. HP 15-R263DX Disassembly, HP 15-R263DX Disassembly: adım 4, 2 resimden 1. HP 15-R263DX Disassembly, HP 15-R263DX Disassembly: adım 4, 2 resimden 2.
    • Locate the two corner grips on the hinge side of the computer.
    • Using a metal spudger, remove the two corner grips to reveal the screws.
    FixBot'a Sor
    Yorum Ekle
  5. HP 15-R263DX Disassembly: adım 5, 1 resimden 1.
    • Remove the 11 small screws on the bottom of the computer that are shown in the picture.
    FixBot'a Sor
    Yorum Ekle
  6. HP 15-R263DX Disassembly: adım 6, 1 resimden 1.
    • Remove the 2 small screws that are on the bottom side of the disc tray slot.
    • These screws are shorter and wider than the others.
    FixBot'a Sor
    Yorum Ekle
  7. HP 15-R263DX Disassembly: adım 7, 2 resimden 1. HP 15-R263DX Disassembly: adım 7, 2 resimden 2.
    • Once the keyboard is loose, do not immediately pull away from computer. It is attached by the ribbon connector.
    • Using a spudger, pry around the edges of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
    • To disconnect the ribbon connector, flip up the black clip shown in the picture.
    • Gently pull the ribbon until disconnected.
    FixBot'a Sor
    Yorum Ekle
  8. HP 15-R263DX Disassembly: adım 8, 2 resimden 1. HP 15-R263DX Disassembly: adım 8, 2 resimden 2.
    • Disconnect the other two ribbon connectors underneath the keyboard by fliping up the black clips.
    • Remove the 4 small screws shown in the picture.
    FixBot'a Sor
    Yorum Ekle
  9. HP 15-R263DX Disassembly: adım 9, 1 resimden 1.
    • Disengage the face plate clips by prying the case away from around the outer edge of the face plate with a metal wedge.
    • The face plate can then be lifted away from the computer.
    FixBot'a Sor
    Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Dilan Johnson
723 İtibar
4 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 47
Her zaman: 7,021
