Ana içeriğe geç
HP 15-R263DX Hard Drive Replacement
Neye ihtiyacın var
    1. HP 15-R263DX Hard Drive Replacement, Battery: adım 1, 2 resimden 1. HP 15-R263DX Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
      • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
      • Slide the battery out as shown in the picture.
      FixBot'a Sor
      Yorum Ekle
    1. HP 15-R263DX Hard Drive Replacement, Optical Drive: adım 2, 2 resimden 1. HP 15-R263DX Hard Drive Replacement, Optical Drive: adım 2, 2 resimden 2.
      • Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
      FixBot'a Sor
      Yorum Ekle
    2. HP 15-R263DX Hard Drive Replacement: adım 3, 1 resimden 1.
      • Gently slide the optical drive out of the side of the computer.
      FixBot'a Sor
      Yorum Ekle
    1. HP 15-R263DX Hard Drive Replacement, HP 15-R263DX Disassembly: adım 4, 2 resimden 1. HP 15-R263DX Hard Drive Replacement, HP 15-R263DX Disassembly: adım 4, 2 resimden 2.
      • Locate the two corner grips on the hinge side of the computer.
      • Using a metal spudger, remove the two corner grips to reveal the screws.
      FixBot'a Sor
      Yorum Ekle
    2. HP 15-R263DX Hard Drive Replacement: adım 5, 1 resimden 1.
      • Remove the 11 small screws on the bottom of the computer that are shown in the picture.
      FixBot'a Sor
      Yorum Ekle
    3. HP 15-R263DX Hard Drive Replacement: adım 6, 1 resimden 1.
      • Remove the 2 small screws that are on the bottom side of the disc tray slot.
      • These screws are shorter and wider than the others.
      FixBot'a Sor
      Yorum Ekle
    4. HP 15-R263DX Hard Drive Replacement: adım 7, 2 resimden 1. HP 15-R263DX Hard Drive Replacement: adım 7, 2 resimden 2.
      • Once the keyboard is loose, do not immediately pull away from computer. It is attached by the ribbon connector.
      • Using a spudger, pry around the edges of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
      • To disconnect the ribbon connector, flip up the black clip shown in the picture.
      • Gently pull the ribbon until disconnected.
      FixBot'a Sor
      Yorum Ekle
    5. HP 15-R263DX Hard Drive Replacement: adım 8, 2 resimden 1. HP 15-R263DX Hard Drive Replacement: adım 8, 2 resimden 2.
      • Disconnect the other two ribbon connectors underneath the keyboard by fliping up the black clips.
      • Remove the 4 small screws shown in the picture.
      FixBot'a Sor
      Yorum Ekle
    6. HP 15-R263DX Hard Drive Replacement: adım 9, 1 resimden 1.
      • Disengage the face plate clips by prying the case away from around the outer edge of the face plate with a metal wedge.
      • The face plate can then be lifted away from the computer.
      FixBot'a Sor
      Yorum Ekle
    1. HP 15-R263DX Hard Drive Replacement, Hard Drive: adım 10, 1 resimden 1.
      • Remove the 2 black screws holding the hard drive to the computer frame.
      FixBot'a Sor
      Yorum Ekle
    2. HP 15-R263DX Hard Drive Replacement: adım 11, 2 resimden 1. HP 15-R263DX Hard Drive Replacement: adım 11, 2 resimden 2.
      • Gently slide the hard drive away from the motherboard to disconnect it.
      • After it's disconnected, lift the hard drive up to remove it from the computer.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Drake Hort
487 İtibar
3 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 1,917
