Ana içeriğe geç
HP 15-ac121dx Back Panel Replacement
Neye ihtiyacın var
  1. HP 15-ac121dx Back Panel Replacement, Battery: adım 1, 1 resimden 1.
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx Back Panel Replacement: adım 2, 1 resimden 1.
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx Back Panel Replacement: adım 3, 2 resimden 1. HP 15-ac121dx Back Panel Replacement: adım 3, 2 resimden 2.
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx Back Panel Replacement: adım 4, 2 resimden 1. HP 15-ac121dx Back Panel Replacement: adım 4, 2 resimden 2.
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx Back Panel Replacement, Back Panel: adım 5, 2 resimden 1. HP 15-ac121dx Back Panel Replacement, Back Panel: adım 5, 2 resimden 2.
    • Place the laptop with the back panel facing up and the battery compartment facing away from you.
    • Using a spudger, carefully remove the rubber feet on both sides of the battery compartment.
  6. HP 15-ac121dx Back Panel Replacement: adım 6, 1 resimden 1.
    • Using a Phillips #000 screwdriver, remover the ten 7mm screws on the back panel.
    • Using the same screwdriver, remove the two 5mm Phillips #000 screws on both sides of the battery compartment.
  7. HP 15-ac121dx Back Panel Replacement: adım 7, 1 resimden 1.
    • With the same orientation as the previous step, locate the bottom left corner.
    • Using a plastic opening tool, carefully pry off and remove the back panel.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 960
