Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove all external devices from the computer.
Remove the charging cord from the computer.
To remove the battery, slide the left slider on the back to the unlocked position.
Push the right slider inwards.
Remove the battery out by pulling straight out and to the right.
Locate the CD Compartment panel and gently slide it out.
Remove the back of the laptop by unscrewing the screws shown.
Also remove the other 5 Phillips screws lining the back cover.
Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
Locate the Fan as shown.
Pull out the black cable, with four wires attached from its port.
Pull out the white cable wire from its port.
Unscrew the two black Phillips screws holding in the fan.
Remove fan.
Unscrew the two screws holding in the fan.
Bir başkası bu kılavuzu tamamladı.
