Giriş
This guide will teach you how to replace the motherboard, which contains the USB ports. You will need plastic prying tools and a Phillips J001 screw driver.
Neye ihtiyacın var
Remove all external devices from the computer.
Remove the charging cord from the computer.
Locate the Fan as shown.
Pull out the black cable, with four wires attached from its port.
Locate the four ribbon clips.
Lift the grey part of the ribbon clips.
Pull the ribbon cable out and repeat this step for all four ribbon cables.
Also use a spudger and release the TWO cables attaching the hard drive to the motherboard. Another ribbon cable is located where the fan was sitting.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Pls can the motherboard of HP - 15 ac-250g5 replacethe board of HP 15 ac-121dx since they have the same body structure.
