Ana içeriğe geç
HP 15-ac121dx Screen Replacement
Neye ihtiyacın var
  1. HP 15-ac121dx Screen  Replacement, Battery: adım 1, 1 resimden 1.
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx Screen  Replacement: adım 2, 1 resimden 1.
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx Screen  Replacement: adım 3, 2 resimden 1. HP 15-ac121dx Screen  Replacement: adım 3, 2 resimden 2.
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx Screen  Replacement: adım 4, 2 resimden 1. HP 15-ac121dx Screen  Replacement: adım 4, 2 resimden 2.
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx Screen  Replacement, Screen: adım 5, 1 resimden 1.
    • Open the laptop so that the screen is facing you.
  6. HP 15-ac121dx Screen  Replacement: adım 6, 2 resimden 1. HP 15-ac121dx Screen  Replacement: adım 6, 2 resimden 2.
    • With the screen facing you, use the plastic opening tool to remove the liner around the screen
  7. HP 15-ac121dx Screen  Replacement: adım 7, 1 resimden 1.
    • Using a Phillips #000 screwdriver, remove all four 2mm screws in each corner of the screen.
  8. HP 15-ac121dx Screen  Replacement: adım 8, 2 resimden 1. HP 15-ac121dx Screen  Replacement: adım 8, 2 resimden 2.
    • Carefully remove the screen and place it face down on the keyboard.
    • Do not pull the screen away from the front panel assembly, as this would damage the cord connecting the screen to the front panel assembly.
  9. HP 15-ac121dx Screen  Replacement: adım 9, 2 resimden 1. HP 15-ac121dx Screen  Replacement: adım 9, 2 resimden 2.
    • With the screen faced down on the keyboard, remove the grounding tape adhered to the back of the screen.
    • You should see a 36-pin plug underneath the grounding tape.
    • Carefully remove the 36-pin plug, not to damage the grounding tape or the plug.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 773
