Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
  1. Remove all external devices from the computer.
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. Turn off the computer by holding the power button.
    • Turn off the computer by holding the power button.
  3. To remove the battery, slide the left slider on the back to the unlocked position. To remove the battery, slide the left slider on the back to the unlocked position.
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. Push the right slider inwards. Remove the battery out by pulling straight out and to the right.
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. Open the laptop so that the screen is facing you.
    • Open the laptop so that the screen is facing you.
  6. With the screen facing you, use the plastic opening tool to remove the liner around the screen With the screen facing you, use the plastic opening tool to remove the liner around the screen
    • With the screen facing you, use the plastic opening tool to remove the liner around the screen
  7. Using a Phillips #000 screwdriver, remove all four 2mm screws in each corner of the screen.
    • Using a Phillips #000 screwdriver, remove all four 2mm screws in each corner of the screen.
  8. Carefully remove the screen and place it face down on the keyboard. Do not pull the screen away from the front panel assembly, as this would damage the cord connecting the screen to the front panel assembly.
    • Carefully remove the screen and place it face down on the keyboard.
    • Do not pull the screen away from the front panel assembly, as this would damage the cord connecting the screen to the front panel assembly.
  9. With the screen faced down on the keyboard, remove the grounding tape adhered to the back of the screen. You should see a 36-pin plug underneath the grounding tape.
    • With the screen faced down on the keyboard, remove the grounding tape adhered to the back of the screen.
    • You should see a 36-pin plug underneath the grounding tape.
    • Carefully remove the 36-pin plug, not to damage the grounding tape or the plug.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 237
