Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove all external devices from the computer.
Remove the charging cord from the computer.
To remove the battery, slide the left slider on the back to the unlocked position.
Push the right slider inwards.
Remove the battery out by pulling straight out and to the right.
With the screen facing you, use the plastic opening tool to remove the liner around the screen
Using a Phillips #000 screwdriver, remove all four 2mm screws in each corner of the screen.
Carefully remove the screen and place it face down on the keyboard.
With the screen faced down on the keyboard, remove the grounding tape adhered to the back of the screen.
Carefully remove the 36-pin plug, not to damage the grounding tape or the plug.
